Official BF 109 Campaign
Emeritus
KitMaker: 2,845 posts
AeroScale: 1,564 posts
Posted: Friday, August 27, 2010 - 04:49 AM UTC
There's free image editing software around too, like Irfanview and GIMP for example.
Emeritus
Posted: Friday, August 27, 2010 - 11:53 AM UTC
Well, since it's long enough after that last post of mine so I can't edit it anymore, so here goes with a new one. Some more progress again:
Another shock absorbing spring, this one will go to the antenna wire.
Cockpit UV lights, made from styrene rod, left-over PE straps and thin metal wire.
I also got the wheels painted up. I'll be adding some mud and dust later on.
Eduard's main wheel masks fit the Ultracast wheels nicely.
It was the same thing for the canopies themself, save for the windscreen piece, which was both a bit too tall and wide. That was easily fixed though, by quartering the piece and placing them so they overlapped each other.
Painting's underway!
Done freehand as I both wanted to save the time spent masking and see how it would look. I'll get going with the fuselage greys when I get the canopy front and rear section in place, which should be soon.
Posted: Friday, August 27, 2010 - 10:42 PM UTC
@ Eetu
Beautiful looking plane you got there. By my estimate, i shall reach your skill level by the year 2249 AD
Progress Update on my Gelb 4 of I./JG27
I know i got the style of the "4" wrong....but my pilot wanted it that way only
Removed by original poster on 08/28/10 - 15:01:39 (GMT).
Removed by original poster on 08/28/10 - 15:08:18 (GMT).
f18fixer
KitMaker: 29 posts
AeroScale: 15 posts
Posted: Saturday, August 28, 2010 - 04:11 AM UTC
Here is my Classic Airframes ME-109 C/D , I hope you enjoy
Craig
Craig
bill_c
KitMaker: 10,553 posts
AeroScale: 1,198 posts
Posted: Monday, August 30, 2010 - 02:57 AM UTC
Nice early camo scheme!
Emeritus
Posted: Monday, August 30, 2010 - 08:34 AM UTC
Camo done, first coats of future on:
As I just don't seem to able to get a decaling-proper gloss by airbrushing Future, I'll probably do as before, go over the areas to be decaled with a good old brush.
What do you think of those overpainted German crosses on the wings? I tried the same trick I succesfully pulled off with the last 1:72 scale Bf 109 I built: cutting out the crosses from the decals and using them as airbrushing masks, held slightly above the surface of the wing with blobs of blu-tac. This time I messed it up though by mixing the overpainting grey too dark and spraying too heavily (ie. covering too well), making the effect way too dark and hard-edged. The picture above is taken after my first attempt to fix it, misting RLM74 (the surrounding colour) unevenly over them.
I think I'll have to go over them again.
Emeritus
Posted: Tuesday, August 31, 2010 - 01:13 AM UTC
After another go, this time with a lighter-than-the-background mix of RLM74 and 02. Appears a bit starker in the picture than in reality.
Next stop: decals.
Next stop: decals.
Posted: Tuesday, August 31, 2010 - 01:20 AM UTC
Hi all
Eetu .. I see you go very much over board with your build. Very detailed and very well done. I did the contrary and the result is best seen like on this picture:
I'll take more pix later
cheers
Steffen
cheers
Steffen
Posted: Tuesday, August 31, 2010 - 02:38 AM UTC
Finished
Learned a lot from all the great builds here. Thanks Terri for a great campaign. All comments / suggestions / advice welcome.
Posted: Tuesday, August 31, 2010 - 02:46 AM UTC
Very nice so far Raj ! The camo turned out really well .
Hi Craig , excellent job on an oldie 109 !
Eetu , what can say , well done so far . I have made that same mistake before . When building the BE2-c I tried to have a see through effect but was little heavy with the misting of paint . You just barely see the markings .
Looking forward to the next up date .
Steffen , was this one out of box and where did you get the figure ?
I have my clear coat on ready for decals , pic's coming soon ...
Posted: Tuesday, August 31, 2010 - 03:24 AM UTC
Hi Terri
Academy oob .. well almost. Some parts from Hasegawa kit and some "scratch" stuff. I wanted to test the camo decals from the kit, which worked quite well. I adjusted them a bit as I wanted a different marking. Here is another picture of the finished model:
You can find mor in my BLog here on Aeroscale.
The figure is Kurenai no Buta aka Porco Rosso aka Crimson Pig from the Fine Molds kit of the "Savoia S.21" (and I need to touch up a bit on it + flat coat)
cheers
Steffen
cheers
Steffen
f18fixer
KitMaker: 29 posts
AeroScale: 15 posts
Posted: Tuesday, August 31, 2010 - 05:43 AM UTC
Eetu...Great work..love the paint job, its going to be a beauty when you are finished..Well done
Steffen..One of my favorite models of the 109, great work and I really like the JG26 markings
Raj..Awsome Desert camo on your 109..looks like its ready to take on the brits..LOL
And thanks everyone for the kind remarks on my 109, wish I had better pictures..I'll try and get some more soon
Later.....Craig
Later.....Craig
cinzano
KitMaker: 419 posts
AeroScale: 378 posts
Posted: Tuesday, August 31, 2010 - 04:49 PM UTC
Bwahaha. Busy but by no means out of this. I fully plan to have at least one bird ready by deadline. It took me a while to settle on a paint scheme for my Monogram G-10 but stumbled upon a curious JG-54 Gustav with a black nose, a replacement cowl with an earlier 74/75/76 scheme and an overall RLM 83 upper surfaces.
Green should go on the next day or so and then its to decals and weathering.
Fred
Fred
Snorri23
KitMaker: 514 posts
AeroScale: 244 posts
Posted: Tuesday, August 31, 2010 - 05:40 PM UTC
Here is my completed a/c not totally happy with the finish on the kit, painting is a learning process. Thus the no close ups.I now know what not to do on the next one. With this Otaki kit I added cutting edge props and hub, ultracast seat, td wheels and changed the rudder with a tall tail from a Fujimi kit. The chord was narrower then the kit thus some judicious sanding to get it to mate. This has been my first campaign, I have enjoyed it and will engage in another one which will be P-40, and heavy fighter.
Snorri23
KitMaker: 514 posts
Posted: Wednesday, September 01, 2010 - 07:13 AM UTC
If you would like to see different shots of the a/c just let me know. Still learning which pics to post. I am pertaining to the Italian 109 which is above
Posted: Thursday, September 02, 2010 - 01:09 AM UTC
Nice build, Trevor. The Italian markings an a little extra "flavour" to the build. very nice.
An over all 3/4 shot would be cool and a close up of the engine cowling marking.
cinzano
KitMaker: 419 posts
Posted: Thursday, September 02, 2010 - 01:51 AM UTC
Onward and upwards! (looks like we're going to have a lot of nice submissions for this campaign)
OK, making a bit more progress before work today. Hit the plane with RLM 83 (added a drop of black) then re-shot the panels with plain RLM 83. Next step Defense of Reich bands then clear coat and decals!
Woohoo!
Fred
Woohoo!
Fred
Posted: Thursday, September 02, 2010 - 01:45 PM UTC
Wow you guy's are producing some very fine builds so far !
Fred , nice to see you still here with your project ! For a minute there I thought you vanished and joined the carpet monster
Here is progress of my build so far . just have the canopy to finish off , landing gear and I total forgot about the wing slants and have those as well .
Still have the dullcote and a little bit of weathering but not much .
More to follow soon
More to follow soon
Posted: Saturday, September 04, 2010 - 02:15 PM UTC
Just finished spraying the dull cote and canopy is almost finished too boot !
Weathering will start tomorrow
HeyLoad
KitMaker: 64 posts
AeroScale: 33 posts
Posted: Sunday, September 05, 2010 - 03:21 AM UTC
I have finally completed my Hasegawa 1/48 Bf 109 E1 from I./JG 26 Summer 1939. The markings are from Krzysztof Janowicz' book 'JG 26 Schlageter, Vol 1' which included the decals. Thanks for leading the campaign Terry.
Tom
Tom
Posted: Sunday, September 05, 2010 - 05:24 AM UTC
@ Terri
I uploaded only one pic into the Campaign Gallery. Will that be fine or should i upload more??
Kornbeef
KitMaker: 1,667 posts
AeroScale: 1,551 posts
Posted: Sunday, September 05, 2010 - 06:25 AM UTC
Terri I'm just wondering when exactly this campaign closes..
seeing as I'm building the E-7 trop as we speak, I thought this campaing was all but over?
K
K
Kornbeef
Posted: Sunday, September 05, 2010 - 12:52 PM UTC
No matter Terri, Kornbeef used his brain, I know the times short nd my track record isnt good but have enlisted.
Kit:-
Eduard Bf109E-7 trop. Started a little while ago ad looks good to finish before the end of campaign date. Just let me know if thats okay or if I dont qualify
http://aeroscale.kitmaker.net/forums/163417&page=1
Ta Keith
Kit:-
Ta Keith
