I just would like to add that I have posted a build report of my Ki 10 on my website .. some more pix too. I am still amazed that I could put the model together in such a little time..
Metodi---Great work on your P-39 so far. The Red-Bordered stars and bars really contrast well with that scheme.
Steffen--Beautiful presentation on the KI-10.
Well the F-4"Sierra" is done and posted in the gallery. It was completed with the following enhancements:
CAM Resin Martin Baker bang seats CAM -S model Resin Wing Slat Conversion CAM Decals for VF-302 Eduard PE RBF tags Scratchbuilt intake and exhaust covers RIO'S panel was completely wired Scratchbuilt underside reinforcement spar for -S model Helmets removed from crew figures (OUCH!!) and drilled out and then decalled with decal stock and additionl markings hand drawn with a micron pen.
The plane depicted is "Stallion Two-Zero-Zero" from the "Stallions" of VF-302, Reserve Air Wing-30, NAS Miramar, early '80's .
WHEN YOU ARE OUT OF F-PHOUR'S YOU ARE OUT OF PHIGHTERS!!
This has been a very enjoyable campaign and the level of workmanship from the modellers in this crew is extremely impressive...as always.
Best wishes, Ian
It is a fact that under equal conditions, large-scale battles and whole wars are won by troops which have a strong will for victory, clear goals before them, high moral standards, and devotion to the banner under which they go into battle.
-Georgy Zhukov
amegan
#243
England - North East, United Kingdom Joined: March 21, 2008
KitMaker: 996 posts
AeroScale: 915 posts
Ian, a very impressive model of a subject I never thought a great deal of, until I read that Eric (Winkle) Brown thought the F-4 Was the finest jet fighter he ever flew, and he flew most of them. Anyway, the cockpit is one of the best I have ever seen, well done.
Andrew
Pfalz DIIIa, Eduard 1/48 Uffz Max Hitschler Jasta 18 Late 1917
SaxonTheShiba
United States Joined: February 01, 2009
KitMaker: 1,233 posts
AeroScale: 663 posts
Andrew, thanks for the compliment.! Great thing about 32 scale cockpits is that you can really detail them out. Downside is where to put a two foot long airplane. Anyway, thanks again sir.
Best wishes, Ian
-Georgy Zhukov
Siderius
Tennessee, United States Joined: September 20, 2005
KitMaker: 1,747 posts
AeroScale: 1,673 posts
The F-4 is an absolutely gorgeous kit. A stupendous job. Here are some of the photos of my RHAF Bf 109 which is in lieu of the Do 17-z10. Which I was running out of time to complete.
SaxonTheShiba
Trevor----stunning -109, to say the least. Beautiful work in regards to the mottling on the camo scheme and a very eye-catching finish.
Best wishes, Ian
-Georgy Zhukov
Dragon164
#226
British Columbia, Canada Joined: February 20, 2012
KitMaker: 1,909 posts
AeroScale: 508 posts
Got some primer on and my putty and scribe job isn't so bad so I will be doing a natural metal finish. I have a question though, I will be using AlcladII should I use a regular finish or a high shine finish?
Cheers Rob.
Anything without guns is a target!
27 completed campaigns and counting :)
SaxonTheShiba
Thanks Rob. If you are doing an in-theater -38 I would probably use the regular Alclad finish. I think the sheen on that is about right without being too shiny. The model looks great.
Regards, Ian
-Georgy Zhukov
Dragon164
#226
Richard, congrats on finishing your fine model. One of my favorite aircraft and very well done.
Ian, congrats on your finished build.It sure looks great - very impressive!
Others: I'm looking forward to see your finished builds!
Update time:
Markings have been applied. Since the pictures were taken the model has received a gloss coat, stencils and then another gloss coat. Next up is weathering.
Cheers!
Currently on the work bench:
Tamiya Gloster Meteor 1/48 - almost finished
Hasegawa Ju 87D Stuka 1/32 - soon to be painted
Eduard Lysander Mk III on skis 1/48 (stalled)
Revell Ju 88 1/32 (aftermarket items collected)
camogirl
England - North East, United Kingdom Joined: October 20, 2005
KitMaker: 1,045 posts
AeroScale: 622 posts
Kenneth and Sam---thanks for the kind words regarding the "Rhino".
Kenneth---the 109 looks great and a very nice job regarding the camo.
Rob---sweet looking NMF base coat. Smooth!!!!!
Metodi----great weathering on the national insignia on your -39.
RAM ON!!!!!
Best wishes, Ian
-Georgy Zhukov
Dragon164
#226
I thought I was going to have problems with the finish as I only have two armour kits under my belt using an airbrush and it's my first time using Alclad II that and all the filling and sanding I am quite surprised that it came out as good as it did.
Here is a shot after a little clean up and a second coat, that's it for the metal finish now onto colours and markings.
Cheers Rob.
Delbert
#073
Pennsylvania, United States Joined: October 05, 2002
KitMaker: 2,659 posts
AeroScale: 209 posts
Here is the next installment of my Lindberg ME 262 kit
I took a couple of extra days for the assembly to fill and sand a few seams, they are not perfect but the aircraft already has less gaps than the finished model on the box art. LOL.
The last aircraft I did was a Sea Vixen and I had to respray the white several times.
on this kit I started out with the RLM 76 (Model Master) light blue for the underside and used it for the topside primer as I have a couple of spots to sand yet.
I used a Badger Krome at about 18 psi. And it just rocked. here is the photo.
sorry if I seem a bit long winded. Delbert
Just Your Everyday Average Model Builder
SaxonTheShiba
Delbert---the -262 is coming along nicely. Glad the Badger Krome worked well. I have heard good things about it.
Unfortunately my VF-302 "Stallions" patch arrived in the mail after I had already shot and posted the F-4S. So here is the patch without the airplane because I didn't want to beat a "dead horse". HAH! Very cool design.....
Regards everybody, Ian
-Georgy Zhukov
camogirl
I did my research, Got my colors all ready for the paint. I carefully started out my mottling job..
I went with late war RLM 82 light green and RLM 81 brown violet.
The green went on great, got the top of all the wing and tail surfaces and along the top of the aircraft.
started trying the mottling of the RLM 81 and the paint brush decided to get a mind of its own and add to much paint everywhere i tried to go lightly..
so here is an aircraft that started out mottled, wound up in splinter camo, and the ground crew threw in some squiggles for free..
not my best i'll admit, but its unique. so far.
Delbert back to the books
Delbert
#073
Posted: Wednesday, October 24, 2012 - 02:33 PM UTC
me again.
Well as you can see from the previous post that my first attempt at a free hand airbrush camo mottle scheme just didn't work out.
I resprayed my 262 with the RLM 76 Light Blue, which covers well by the way.
I didn't like the RLM 82 Bright Green / RLM 81 brown violet colors.
I've read that some aircraft substituted RLM 83 Dark-Green for the bright RLM 82 and that is what I'm doing now. I like this color a lot more. Will be adding the RLM 81 later.
here is the progress so far.
thanks for looking Delbert
mrockhill
Pennsylvania, United States Joined: June 17, 2009
KitMaker: 566 posts
AeroScale: 507 posts
Posted: Wednesday, October 24, 2012 - 02:45 PM UTC
No pics for this update on my Zero since things havent changed enough to warrant some. I had applied the decals, initially using future to set them. After not seeing much in the way of conforming to panel lines, I hit them with microsol and with some work got the most stubborn ones to settle in. The upper wing hinomarus were the hardest since the nav lights are right in the middle of them. The decals had some raised edges in a few places. Im not really sure why but it was unacceptable so I decided to sand them down. I was glad I did as they blended in nicely with a few minor touch ups required. Today I sealed them down and finished up some deallimg loose ends on the landing gear and prop. As a side note, My PC kicked the bucket last thursday, so instead of building, I spent the weekend turning lead into gold to replace it. Needless to say Im behind but think I can still manage a landing next week... on fumes
"...Fat, drunk, and stupid is no way to go through life son"
Bigrip74
Texas, United States Joined: February 22, 2008
KitMaker: 5,026 posts
AeroScale: 2,811 posts
Posted: Wednesday, October 24, 2012 - 02:55 PM UTC
Delbert, you have broken ground for my own journey into that realm of a/b mottleing BTW I thought that your first attempt was pretty good even if the ground crew were still drunk after the fumes your second attemp looks really good and that Lindburg kit is looking like a champ now. Its settled I will order mine this weekend to join you in a/b practicing
Bob
If it aint broke dont fix it.
camogirl
Posted: Wednesday, October 24, 2012 - 06:40 PM UTC
Delbert the 262 is looking great youve done really well with the airbrush ( have to admit I prefer the colours used on the second attempt but only because mine is done in those colours )
Mike glad you got the decals sorted sounds like you are pretty much done everything crossed for a finish for you.
